1985 Ford Thunderbird Bubbles
RUBERDUK
Hey guys. I have a 1985 ford Thunderbird, I have just recently changed my radiator because i was having issues as far as pressure in my radiator. Radiator was badly clogged. I was getting tiny bubbles in which looked like soap in my resevour tank, and bubbling out through the cap. Now im getting bigger bubbles like I have air in the system. I changed my radiator and my thermostat. Seemed to fix the problem. But today I noticed my temp gauge was acting crazy going from cool to hot and back down. didnt stay hot just went up for a split second and dropeed back down and stayed at cool for the rest of my trip to work. Thought my thermostat may be sticking because its new. well when I got home let my engine cool for about 2-3 hours. I went out popped the radiator cap. In which still a little back pressure., like it was still hot. Filled up Radiator, left cap off started car, and noticed that water wasnt circulating through. And also when I revved it up kinda high in park, the top radiator hose sucked shut. I Was wandering if the water pump isnt working properly will the water back up in radiator and cause pressure causing the thermstat to read hot? and will it cause air bubbles in my water system? I have been told my head gaskets may be leaking pressure into the water system.. So can u help me??? I dont have the cash to keep sticking in the car.
Jun 6, 2007 at 10:45 AM
SERVICE WRITER
  • 9,123 POSTS
Cars always suck cash....repairs and or payments.
Pick up a chemical at the parts store that can be added to the coolant that will change colors when exhaust fumes are present in the coolant. DO you have a 3.8 motor? common for headgaskets.
Jun 6, 2007 at 11:46 AM
Suggested Repair
Add a parts-store chemical coolant test that changes color if exhaust gases are present. A positive result points to a leaking head gasket, which is common on the 3.8 engine.
Conversation Summary
The owner of a 1985 Ford Thunderbird replaced a clogged radiator and the thermostat after coolant bubbling and pressure. The temperature gauge still spikes briefly, residual pressure remains after cooling, coolant does not circulate with the cap off, and the upper radiator hose collapses when the engine is revved. The owner suspects a bad water pump or a head gasket leaking into the cooling system. The expert recommends a chemical test that changes color if exhaust fumes are in the coolant and notes head gasket failure is common on the 3.8 engine.
