1995 Ford Thunderbird Door Won't Close
RWBRICK
  • 5 POSTS
1995 Thunderbird V8. The driver's side door will hardly close. To get it closed one has to softly put the door abutting the latch, lift up very hard on the end of the door, then push against the door. The latching rod seems to hit the latch mechanism a little high, but I see no way to adjuct the mechanism upwards. The mechanism seems to function when I finger it. The hinges have a little play, though it doesn't seem extraordinary (however I might not be able to tell). What is wrong and what needs to be fixed/replaced?
I've heard that this is not an uncommon problem with these cars.
Thanks for any help. The door closing is getting worse to the point that once in a while it doesn't close at all and I have to drive very carefully/dangerously with one arm out the window holding the door!
Mar 13, 2007 at 3:18 AM
BOOTDOG
  • 665 POSTS
i'd say the hinge pins and the bushings are worn.look in that area closely.
Mar 13, 2007 at 6:55 AM
RWBRICK
  • 5 POSTS
Thanks bootdog. Is it likely both upper ond lower hinges are bad? Or would it be wise to replace both anyway? I'm told that one of the hinges of 95 T-Bird is a dog to get at.....
Is fixing the hinge(s) and then putting the big heavy door back in the correct position hard for a couple of decent shade tree mechanics with a hydrolic floor jack?
Mar 13, 2007 at 10:03 AM
BOOTDOG
  • 665 POSTS
replace one hinge at a time, if you're replacing the whole hinge, or if the bushings and hinge pins are the only thing that is worn you can just replace those. do them one at a time too so you don't have to remove the door.good luck on your repairs.
Mar 13, 2007 at 1:17 PM
RWBRICK
  • 5 POSTS
I'm wearing out my welcome, but a couple of nits: 1) does the hinge need to be removed to replace the pin and bushing? 2) Does replacing pin and bushing require and special tools, presses?
Mar 14, 2007 at 4:27 AM
BOOTDOG
  • 665 POSTS
special tools do help but not necessarily needed. the trick is to knock out the old bushings and pins and knocking in the new. i've done on vehicles with a punch and a hammer. however you feel more comfortable doing it is your call. just when you do it do one at a time, so the door doesn't have to come off. good luck on your repairs
Mar 14, 2007 at 10:02 AM
Suggested Repair
Inspect the door hinges closely for worn hinge pins and bushings. Replace the pins and bushings, or the whole hinge if needed, one hinge at a time so the door does not have to come off. A punch and hammer can knock out the old pins and bushings and install the new ones; special tools help but are not required.
Conversation Summary
The owner of a 1995 Ford Thunderbird said the driver's door barely closes and must be lifted hard while pushing it shut. The latch rod seems to hit the latch a little high, and the hinges have some play. The expert attributed the problem to worn hinge pins and bushings and advised replacing pins and bushings or hinges one at a time so the door stays in place. Special tools can help but a punch and hammer can be used.
