somebody please help me??
MATTS94SC
I have a 94 thunderbird I just put a 84 302 that i built in it. i used the factory (downflow) supercoupe radiator (small thing). changed everything to v-belt. got everything ready started it let it run for about 5 minutes and it popped a freeze plug on the front driver side. so i put in a x-pansion plug and tried again. ran for about 10 minutes, boom!! the rear driver side popped out. so another x-pansion and aother plug the middle one so I am now confused. I had everything fluxed before assembly all good. bored the block .40 over all good no cracks. So whats causing my plugs to pop? think it could be the radiator?? PLEASE HELP ME!!!!!
Dec 22, 2006 at 4:38 PM
INDYUKE
  • 416 POSTS
There could be a possibility that your cooling system pressure is rising above maximum.
Dec 22, 2006 at 4:56 PM
MATTS94SC
Well could it be cooling or maybe my block cracked? is it possible for the coolant to build that much pressure?
Dec 22, 2006 at 5:01 PM
INDYUKE
  • 416 POSTS
Your block might be cracked. I was thinking maybe the radiator cap wasn't working correctly and releasing pressure should the pressure rise. I've heard of freeze plugs coming out, though that was in addition to hoses blowing and seals rupturing as well. Is the coolant temp fine?
Dec 23, 2006 at 9:43 AM
MATTS94SC
no it wont even run long enough to get over 120deg. then one pops out.
Dec 23, 2006 at 9:58 AM
SERVICE WRITER
  • 9,123 POSTS
My guess or starting point would be to compression test all the cylinders. It sounds like the cooling system is being pressurized possibly from head gasket or crack as previously mentioned. I've seen weak radiators blow open from a bad headgasket, but yours is new.
OF course then again, I am only a service writer :)
Dec 23, 2006 at 11:55 AM
MATTS94SC
well, I took the heads off and the gaskets where still in good shape the bottom head bolts werent tourqed all that good. but i figured that would cause more other problems.
Dec 23, 2006 at 1:16 PM
INDYUKE
  • 416 POSTS
This is a massive stab in the dark, but how tight are the freeze plugs in there? Could there be a possibility that with the slight rise in temp, the engine block expands thus loosening the freeze plugs (that are under at least some pressure) enough to pop out?
Dec 27, 2006 at 12:57 PM
SERVICE WRITER
  • 9,123 POSTS
Seems like auto repair has a lot of theory huh? If the head bolts weren't torqued right (and possibly leaking)the cooling system may have been getting pressurized.
Dec 28, 2006 at 9:17 AM
INDYUKE
  • 416 POSTS
Service Writer has a good point
Dec 28, 2006 at 12:00 PM
