Rear tire locked up on 87 Thunderbird.
MATTHEWYOHANN
I have a 87 T-Bird with an automatic transmision with the 5.0 V8.
The car sat for about a year without moving.
I replaced the rear brake shoes and the car was drivable.
The car sat for three more months and when I started it the belt was spining around the air pump pulley and smoking.
I replaced the water pump and the air pump and the motor rums good now but when I went to take the car for a ride the car wouldn't go forward.
The car would move in reverse but not drive, I tried drive 1 and drive 2 but it still wouldn't move forward.
The passenger side rear tire spins but the rear drivers side tire doesn't.
I don't know what would cause that, wheel bearing, transmision, I just don't know.
If anyone has any ideas on what to do or what the problem might be it would be greatly apreciated.
Nov 10, 2007 at 11:47 AM
CALLTRIP
sounds like your hub has frozen up. Try removing tire use a dead blow hammer or something to hit around the hub and try to see if the hub will turn. if not spray with wd-40 or any good spray lub work hub to see if it will turn. If this doesn,t work and hub will still not turn then remove hub and check your bearings. They could be frozen up. after a cqr sets up for awhile things will freeze up from nonuse. Hope this helps.
I am not a paid mech. only learn from past things :)
Nov 10, 2007 at 3:26 PM
