Leak
FORD THUNDERBIRD
BARBMCKOWN
97 Ford Thunderbird 156,000 miles. Leaking rusty water...not sure from where?? I thought it was the water pump...but would that water be rusty??? Now I am thinking that it may be the Radiator. Car still running good...no hesitation...Just have to keep filling the coolant back up.
May 18, 2006 at 8:19 AM
LOSONE
  • 1,616 POSTS
If the coolant has never been changed every 30K miles it will be VERY rusty!
A water pump or a heater bypass is a common leak. Have it pressure tested before you have a failure.
May 18, 2006 at 9:53 AM
