1995 Ford Thunderbird Stumbles When Cold
JULIEMAY
I have a 1995 Ford Thunderbird /V8/Auto/ 71,000 miles. Check engine lite came on 2000 miles ago. Tech said it was MAF sensor. Car runs excellent, idles perfect, cruises great, accelerates good. Only problem I have is that it has to be warmed up well otherwise it stumbles on acceleration until it warms up. Ambient temp doesn't make a difference. It does not stall but almost dies and then kicks in and goes.
Any thoughts?
Feb 27, 2006 at 3:59 PM
  • 55,808 POSTS
You need to rescan the vehicle. It sounds like it could be is oxygen sensor or a coolant sensor, also check the fuel filter if you have not replace it recently. Please let me know.
Mar 1, 2006 at 3:25 AM
JULIEMAY
Thanks, I'll get a rescan done. If the MAF was the real problem then it shouldn't run as good as it does. I've checked the tubes and hoses between the MAF and throttlebody and don't see any problems. Also could the PVC valve cause a faulty MAR read? If nothing changes with the reading I'll change the coolant sensor.
Regards JulieMay
Mar 1, 2006 at 10:36 AM
Suggested Repair
Rescan the vehicle for codes. Check the oxygen sensor and coolant temperature sensor, and inspect or replace the fuel filter if it has not been replaced recently.
Conversation Summary
A 1995 Ford Thunderbird with 71,000 miles runs well once warm but stumbles on acceleration until fully warmed up, nearly dying before recovering. A prior check-engine light was attributed to the MAF sensor, and the owner found no problems in the MAF-to-throttle-body hoses. The expert advised rescanning and checking the oxygen sensor, coolant sensor, and fuel filter. The owner planned a rescan and possible coolant-sensor replacement and asked whether the PCV valve could affect the MAF reading.
