Car that sits out
T BOUD 66
I have just purchased a 1966 Thunderbird with the 390. The body and paint is in decent shape. My garage already has a couple of classic cars, so the T-bird had to sit outside. Should I use a plastic sheet under the car cover on those rainy days as a water barrier? Some tell me that the plastic will act like a green house and keep moisture in. My though is to cover it with the plastic + car cover on those rainy days (thus keeping the water out of the window area, cowl and trunk areas). What should I do if this car must stay outside? Those 4-post lifts that allow one car to be stored above another are expensive. Thanks for your help,
Harold in Illinois
Mar 25, 2007 at 5:49 PM
SIRGIBBY
  • 32 POSTS
Plastic does act like a green house.... your thought about the car cover and then the plastic when it rains seems good.. they do make some car covers that vent a lil better yet are pretty water tight.. seen em at some auto place once..
One thing that did work for me is I got a car cover made out of a tent type material and sprayed it down with water proofer spray.. worked pretty good.. When it rained alot had to reapply..
Hope it helps!
Mar 26, 2007 at 6:42 AM
