'95 V8 Thunderbird blower relay
JOSH18_2K
My blower turns off and on pretty randomly, so i'm thinking the blower relay is malfunctioning? where is it?
May 8, 2006 at 11:03 AM
LOSONE
  • 1,616 POSTS
There is no blower relay. The power goes from the switch to the blower resistor to the blower motor. The high speed bypasses the resistor and turns the blower to high. Put it on high and see if the problem goes away. If so it is the resistor.
May 8, 2006 at 11:09 AM
JOSH18_2K
the blower turns on and off pretty randomly- doesnt matter where i put the fan speed. when the blowers on, the fan speed settings work fine, and when the blower is off, its completely off. does this sound like a lose wire or soemhting then? it turns on and off so randomly- doesnt require any jiggling (speed bumps) or anyhting like that.
May 10, 2006 at 5:38 PM
LOSONE
  • 1,616 POSTS
The failure rates are 20% switch and 80% resister. I wouild replace the resister first. Good luck
May 11, 2006 at 1:21 AM
