'95' Thunderbird starting problem
CHRIS67
It is a 95 thunderbird with a v6 engine and around 100,000 miles on it. after the car has run for awhile when you shut it off the engine will not start again for a few hours.
Mar 13, 2006 at 7:09 PM
RAYHUT
  • 134 POSTS
sounds like it maybe a sensor gone bad.
Mar 13, 2006 at 9:13 PM
PEPPERMRJ
  • 1,158 POSTS
I'm with Rayhut. Sounds like a bad crankshaft position sensor. Does it have spark when it does not start?
Good luck and post back. :)
Mar 14, 2006 at 12:46 PM
CHRIS67
yes it does have spark when it will not start.
Mar 14, 2006 at 4:15 PM
PEPPERMRJ
  • 1,158 POSTS
https://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
Do you hear the fuel pump running when the key is first turned to the on position?
Good luck and let us know. :)
Mar 15, 2006 at 7:50 AM
CHRIS67
yes the fuel pump is running. I am starting to suspect the problem may be with the ECM unit and i am taking it to be checked out.
Mar 15, 2006 at 3:41 PM
