94 thunderbird transmission
RAIDEN023
94 thunderbird lx 55,500 auto. while i'm driving, my foot will be on the gas and all of a sudden, the tachometer will increase as if i have the car in neutral and reving the engine. i let go of the gas and then gas it again and the car seems to 'jerk' into gear. i just got it recently and it was running in good condition until now. please help. thank you.
Sep 8, 2007 at 11:31 AM
POET042005
  • 134 POSTS
First things first check your fluids to make sure they are up to correct level.
Oct 8, 2007 at 8:47 AM
THUNDERSTRUCKGA
I have also had this same problem with this year model tranny..Once a rebuild @ over 1700 dollars and a year later the same thing. I found an answer that, so far, has worked for me on a Lincoln forum. No, it wont make a bit of sense, but as I said, its working.
Replace the NEUTRAL SAFETY SWITCH and advise me of any good results. They are inexpensive and a much better fix than a rebuild that you dont need.
Hope this works for you as it has for me.
Nov 5, 2007 at 11:37 AM
