'93 T-Bird starter solenoid problems
1993 FORD THUNDERBIRD
WEONIA
Something keeps shorting out my starter solenoid. I've changed it, changed my starter, and repaired the cables that connect to my batteries (they were a bit rusted). Nothing is working. It'll work for about a week or two then short out again. And if I disconnect it and reconnect it, it will start normally for a day or two. I need to know what could be causing this. And how I can fix it without paying too much.
Thank you!! :?
Oct 11, 2007 at 11:33 AM
Below will help you locate the problem from the key, thru the park/neutral position switch,starter relay, and starter motor.
https://images.2carpros.com/forum/automotive_pictures/12900_1993_ford_Tbird_starter_circuit_1.jpg
Oct 16, 2007 at 9:33 PM
