2004 Ford Thunderbird hard starting
EARL KENNEDY
Engine Performance problem
2004 Ford Thunderbird V8 Two Wheel Drive Automatic 15K miles
After sitting idle for about a week or more, the engine cranks for a very long time without indication of starting. Foot feed position seems to have no bearing on the problem.. Finally, it will begin to hit, skip for a second and then catch. Afterwards, no problems and no symptoms. No more porblems until it sits for a week or more.
Got any ideas?
Mar 30, 2010 at 3:34 AM
MERLIN2021
  • 17,250 POSTS
Try this next time, turn the key on for 4 seconds, then off then on for 4 more seconds, repeat four or five times, then see if it starts up OK, If it does, have fuel pressure tested and a bleed down test with it.
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
Mar 30, 2010 at 9:09 AM
