2002 Ford Thunderbird will not start
68,000 MILES • V8 • 2WD • AUTOMATIC
DEANWEBSTER
new battery in my 2002 thunderbird turn the key the gauges go whacky and there is clicking but will not turn over tried jumping but no success as soon as i disconnect the charger it is like there is no battery at all any help
Feb 8, 2009 at 7:57 AM
  • 75,988 POSTS
Test the starter relay
Feb 8, 2009 at 8:09 AM
CASSY
you need to get a cheltons so you now where all the grounds are in the engin if its not grounded right it will act like there is now battery. an if u are putting both jumper cables on the battery an not putting the nagative on the fram of the car there still is now ground u can over charge the battery that way.
Feb 22, 2009 at 1:09 PM
  • 75,988 POSTS
Do a voltage drop test on both positive and negative cables-
Feb 23, 2009 at 1:05 AM
