I have had my 2002 TBird with only 30000 miles into Ford a dozen times since March to fix a leak that occurs at the top of the driver side window. At first it leaked only at the car wash. Now that Ford has worked on it, replaced seals, "tweaked the door" and made numerous adjustments it leaks also while sitting in the rain.
FORD says now....the T Bird should not be taken through a car wash due to the high velocity of water and air. I am guessing that now it shouldn't be taken out in the rain either.
They cannot fix it and now tell me that they can't make it leak....I can't get it to stop. Any suggestions????
Jan 24, 2008 at 8:46 AM
