2002 Ford Thunderbird Ignition Coils
NINETTE
Engine Performance problem
2002 Ford Thunderbird V8 Automatic 122000 miles
I had 2 ignition coils replaced by Ford at a cost of almost $900. Now the car needs more coils replaced and I just can't justify a $1000 bill for 2 more coils each year until they are all replaced. Can I do this work myself? I know absolutely nothing about cars, although I can change a tire. The only mechanic I know is my brother, however he lives 800 miles away.
Aug 18, 2009 at 1:31 AM
WINEBURGER
  • 82 POSTS
what code is coming up .
Aug 18, 2009 at 1:37 AM
NINETTE
I only have the receipt for the work and as far as I can tell there isn't an indication of a code number. However under "description" is printed SP 468 and DG 529. Ford replaced #6 and #7 in January, in April it started misfiring again.
Ninette
Aug 18, 2009 at 2:01 AM
WINEBURGER
  • 82 POSTS
did you change all the spark plug at some point
Aug 18, 2009 at 2:06 AM
NINETTE
Not that I am aware of. I don't believe the car has ever been tuned-up. It has been worked on by one Ford Dealer since I bought it in 2002. they did the scheduled warranty maintenance and then any other issues I may have had in the past.
Aug 18, 2009 at 6:37 AM
WINEBURGER
  • 82 POSTS
platinum plugs usually last around 100000 miles the start going out i would replace plugs for cylinder missfire codes not coils
Aug 18, 2009 at 7:14 AM
NINETTE
Thank you for your rapid response. I'll try replacing the spark plugs first. Now you wouldn't know a great spagetti sauce recipe... :-) Thanks again
Aug 18, 2009 at 8:08 AM
WINEBURGER
  • 82 POSTS
your welcome
Aug 18, 2009 at 8:14 AM
