1998 Ford Thunderbird
BIGDONIE27
Electrical problem
1998 Ford Thunderbird 4 cyl Two Wheel Drive Automatic
my car ahs power but when turning on to start the car the car dies
Aug 28, 2009 at 1:41 PM
  • 75,988 POSTS
Do below and give me some results before we can continue
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Aug 28, 2009 at 1:46 PM
