1997 Ford Thunderbird Trouble Codes
95,000 MILES • V8 • 2WD • AUTOMATIC
RWTBIRD97
  • 11 POSTS
I'm curious to know what these trouble codes mean. The check engine light is on in my car. I have a Hypertech power programmer that I have used to read the codes. Most of the research I have done hasn't gotten me anywhere. Just to let you know my car is entirely stock. I haven't even used the programming feature on the programmer. Also the problem other than the codes is that the engine will not stay running unless I'm gassing it and the exhaust smells VERY rich. What do you suggest I do? Any help would be appreciated.
P0003
P0008
P0080
P0C20
P0C80
P0172
P0175
P0680
P1000
P1AEE
P1280
P1880
Jan 28, 2009 at 2:39 PM
DAVE H
  • 13,383 POSTS
I cannot find any info on the other codes showing .. PO172/175 ..is not an uncommon fault .. check,clean or replace the MAF sensor and do the other checks below !
P0171...System To Lean (Bank 1)
P0172...System To Rich (Bank 1)
P0174...System To Lean (Bank 2)
P0175...System To Rich (Bank 2)
41) DTC P0171, P0172, P0174 Or P0175: HO2S Not Switching DTCs P0171 and P0174 indicate air/fuel ratio is correcting rich for an overly lean condition. DTCs P0172 and P0175 indicate air/fuel ratio is correcting lean for an overly rich condition.
Possible causes are as follows:
Fuel system malfunction.
EGR system malfunction.
Air intake or vacuum system leak.
Engine oil level too high.
Excessive internal engine wear.
Inspect engine for obvious defects in specified systems. Repair or replace as necessary.
Jan 28, 2009 at 10:05 PM
