1997 Ford Thunderbird replacing differential lube
100,000 MILES • V8 • 2WD • AUTOMATIC
IVGOTIT
  • 10 POSTS
The user manual for my 97 Tbird calls for replacement of differential lube at 100k. I have the car up on jacks and can find no drain plug on the differential - only a fill plug. My questionis How do I drain the old lube?? Thanks, Kent
Oct 23, 2009 at 9:16 AM
RYANBLIZZ
  • 35 POSTS
I am sure it is not correct, but I always have removed the housing cover and replaced the gasket (about $10 at O'Reilly's).
I like doing this because I can inspect the teeth and look for any metal shavings.
The only other way I can think to do it is by siphoning with a tube through the filler hole.
Good luck!
Ryan
Oct 26, 2009 at 1:08 PM
