1997 Ford Thunderbird radiator fan stays on all the time
110,000 MILES • V8 • 2WD • AUTOMATIC
IVGOTIT
  • 10 POSTS
My radiator fan motor came one while driving, then stayed on when engine was shut down. It now stays on all the time - I had to disconnect the battery to stop it. the engine is not overheating - there is no reason the fan should be running. How do I fix this? Thanks
Nov 10, 2010 at 1:04 PM
WRENCHTECH
  • 20,760 POSTS
You most likely have a bad CCRM (Constant Control Relay Module).
It's located in the right hand front of engine compartment, mounted to upper radiator support.
Nov 10, 2010 at 11:33 PM
IVGOTIT
  • 10 POSTS
Thank you Wrenchtech - that was it - I took it out, opened it up, found dirt had gotten inside, cleaned it up, cleaned connection pins/socket and now it works just fine!
Nov 11, 2010 at 4:10 AM
