1997 Ford Thunderbird power steering don't work
1997 FORD THUNDERBIRD
GRISHCDG
Steering problem
1997 Ford Thunderbird Two Wheel Drive Automatic 223000 miles
I put in a new power steering pump, and the power steering still does not work. What could be the problem.
May 12, 2010 at 3:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
make sure belt is tightened properly and power steering fluid is full. if OK check hoses for binding and loose connections. if all is good it could be the rack that is bad.
May 12, 2010 at 3:45 PM
