1997 Ford Thunderbird Overheating and Schreeching noises.
1997 FORD THUNDERBIRD
78,000 MILES • 6 CYL • 2WD • AUTOMATIC
JONAHSDAD1214
I recently had my thermostat replace water pump and hoses replaced about six months ago. I have been checking the coolant and it is always full. When i had the waterpump replaced it stoped overheating. 2 months ago it started overheating again. When i turn on the ac or the heater it goes back down to normal, although now there is a schreeching noise when i drive when i am in idle and other times. The noise sounds like a skill saw but way worse with a slight screech. I really dont know what to do. do you have any suggestions.
Aug 21, 2010 at 8:18 PM
  • 110,244 POSTS
Have you checked the belt to make sure it is tight?
Oct 25, 2010 at 6:35 AM
