1997 Ford Thunderbird Idle Issue
160,000 MILES • V8 • 2WD • AUTOMATIC
CLOUSE40
Car starts up, doesn't seem to hold the minimum idle speed because the rpm after starting just decreases until car dies unless I give it gas to keep the car running
Oct 5, 2009 at 5:07 AM
DUMADE
  • 12 POSTS
Better late than never; I have a 1996 TB. Although the idle is suppose to be set by the computer, at the end of the throttle cable is a set screw which you can adjust the idle. It is tight and need Visegrip pliers to clamp on and turn. Hope this helps.
Jan 18, 2010 at 8:45 AM
