1997 Ford Thunderbird fuel pump
DANIELJOHN
  • 1997 FORD THUNDERBIRD
  • 6 CYL
  • 82,000 MILES
When you turn the key 'on' you can feel and hear the fuel pump running. It won't start until the pump stops. Now the pump keeps running and running. If and when it starts, initially it seems starved for fuel. After awhile it runs okay. Also, the radiator/condensor fan runs when key is 'on, ' also stops with pump.
Saturday, October 3rd, 2009 AT 9:38 PM
  • 109,885 POSTS
First, I need you to check the fuel pump pressure. It may be a plugged fuel filter or bad pump causing the problem.
Here is a how to for checking the pump pressure:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Next, the fan and pump are not tied together, but they both have their own seperate relay in the relay box. Check the wiring there to make sure nothing is shorting out.
Let me know what you find.
Sunday, October 4th, 2009 AT 1:43 AM
DANIELJOHN
The pressure test says 40 psi with key 'on.' The car won't start until the pump shuts off. The pump won't shut off. What tells it to stop? Can it be the idle air control? It sounds like it's running also.
Sunday, October 4th, 2009 AT 1:30 PM
KHLOW2008
  • 41,814 POSTS
Hi danieljohn,
The fuel pressure is correct.
Fuel pump relay is controlled by the PCM and fuel pump not stopping at ignition on could mean a faulty PCM.
Get a scan done to see if you could retrieve any trouble codes
Thursday, October 8th, 2009 AT 10:08 AM
