1997 Ford Thunderbird engine missing
101,000 MILES • 6 CYL • 2WD • AUTOMATIC
SPRAD
1997 3.8 thunderbird began missing & runnibg rough especially at idle & low rpms. Problem began overnight with no warnings
Feb 19, 2010 at 6:16 AM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug.
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
Feb 19, 2010 at 7:09 AM
