1997 Ford Thunderbird Does not Start
STJOHN256
  • 1997 FORD THUNDERBIRD
  • V8
  • 140,000 MILES
I have a 1997 T-bird with a 4.6 the car started to run rough then it had no power, so I changed the plugs, wires and coils and now it want even start.
Friday, May 23rd, 2008 AT 9:23 PM
LEGITIMATE007
  • 5,121 POSTS
Check your ignition/spark and check fuel pressure. I'll send links for the video that will show you an easy way to do this in case you don't know how. Then your gonna want to check your crank sensor and your map sensor. In that order
Friday, May 23rd, 2008 AT 10:41 PM
LEGITIMATE007
  • 5,121 POSTS
Go here to check your ignition
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
Friday, May 23rd, 2008 AT 10:43 PM
LEGITIMATE007
  • 5,121 POSTS
Go here for fuel pressure
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Friday, May 23rd, 2008 AT 10:45 PM
