1997 Ford Thunderbird brakelamps
217,768 MILES • V8 • 2WD • AUTOMATIC
SATURDAYKAY
the trunk llid brake\tail lamps are not working. what should I do?
Jun 3, 2010 at 9:50 AM
INTERNETMECHANIC
  • 700 POSTS
Use a voltage tester at the lamp assembly, wiring harness. The brown wire is voltage for the tail lamps, when you turn on the headlamp switch, is that wire hot? Black wire is ground. The other color wire is stop/turn, they use the same bulb filament, not at the same time. Does the highmount brake lite work?
https://images.2carpros.com/forum/automotive_pictures/512072_thunderbird_lamps_1.jpg
Jun 4, 2010 at 3:15 AM
