1996 Ford Thunderbird water got in my intake while i went t
BOBBY CARMONA
Engine Performance problem
1996 Ford Thunderbird 6 cyl Two Wheel Drive Automatic
how do i go about fixing my motor / i think i flooded my intake while going through a lot of water
May 14, 2010 at 2:30 PM
  • 31,937 POSTS
HI there,
Remove air cleaner and discard if wet, remove spark plugs and crank over, stand back as any water in cylinders will be ejected with force, do a comp test to be on the safe side, if OK, replace plugs and run, the fuel system will be OK.
Mark (mhpautos)
May 14, 2010 at 3:19 PM
