1996 Ford Thunderbird OIL PUMP
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOBBY TALFORD
hOW DO YOU REMOVE OIL PUMP
Nov 4, 2010 at 4:48 AM
  • 110,251 POSTS
You need to remove the oil pan first. Once removed, the pump is bolted on the rear main.
Nov 5, 2010 at 4:24 AM
BOBBY TALFORD
Would i have to pull out the engine
Nov 5, 2010 at 4:31 AM
  • 110,251 POSTS
If you are lucky, no. You may be able to lift it enough high enough by just unbolting the motor mounts.
Nov 5, 2010 at 5:01 AM
