Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Thunderbird
Engine
Oil Pump
Replace/Remove
1996 Ford Thunderbird OIL PUMP
1996 FORD THUNDERBIRD
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOBBY TALFORD
MEMBER
hOW DO YOU REMOVE OIL PUMP
Nov 4, 2010 at 4:48 AM
Experienced Mechanic
You need to remove the oil pan first. Once removed, the pump is bolted on the rear main.
Nov 5, 2010 at 4:24 AM
BOBBY TALFORD
MEMBER
Would i have to pull out the engine
Nov 5, 2010 at 4:31 AM
If you are lucky, no. You may be able to lift it enough high enough by just unbolting the motor mounts.
Nov 5, 2010 at 5:01 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
