1996 Ford Thunderbird Need to know how to
1996 FORD THUNDERBIRD
ZECHERIAH619
1996 Ford Thunderbird 6 cyl Two Wheel Drive Automatic 186k miles
My Tbird's rear end went out. We got the replacement rear end but i cnt seem to find any information on how to swap it out the old with new on my own. I have access to just about any tool that would be needed. I just dont have the know how or money to get an expensive manual. If you could give me some information so i know what im doing it would be greatly appreciated.
Sep 11, 2009 at 5:52 AM
RYANBLIZZ
  • 35 POSTS
I have done, it is a two person job - expect it to take 3-4 hours.
I upgraded my brakes from drum to disc, and replaced shocks, so I may have done more than required to get it out.
I started by draining the rear-end, then removed my tires, then removed my brake drums. You will have to remove the axle nut holding your half shaft in place. I think you should be able to get the half shaft out without any more disassembly, but I did not try... Once removed from the wheel assembly give it a solid tug from the rear-end and it should come right out.
You will have to disconnect the drive shaft from the rear-end and then remove the four bolts holding the bracket onto the rear suspension.
It should drop out and you should be able to reverse these steps and put the new one back in. Make sure you replace the half shafts while they are out if they are bad (they are like a $80 core charge each).
I am sorry if I forgot anything on this. It has been awhile and my repair was a little more extensive than what you are trying to do.
Good luck,
Ryan
Sep 16, 2009 at 1:40 PM
