1994 Ford Thunderbird aode transmission
TILLAMOOKHEAD
  • 9 POSTS
Drive Train Axles Bearings problem
1994 Ford Thunderbird V8 Two Wheel Drive Automatic
hi again. i have a 94 thunderbird with a 4.6 engine and a crap AODE tranny. will a rebuilt AODE tranny from a 93 5.0 mate to the 4.6?
if not, what are my options?
Nov 4, 2008 at 3:19 PM
JNOVACK
  • 723 POSTS
it must be a 4.6 you can use one out of a couger, crown vic, mercery grand Marquis
Nov 5, 2008 at 11:16 AM
TILLAMOOKHEAD
  • 9 POSTS
i read an article about using a 5.0 safety bellhousing on a 4.6 engine. i think i can use this method to put a 5.0 aode trans. onto the 4.6 engine. should i use the 4.6 torque converter or does it matter. what else should i consider?
Nov 6, 2008 at 10:42 AM
JNOVACK
  • 723 POSTS
if youre using a trany out of a 5.0 you will need to use 5.0 converter and you will need to change the flywheel to bolt it up
Nov 7, 2008 at 12:31 AM
