1996 Ford Thunderbird High Idle
210,000 MILES • 6 CYL • 2WD • AUTOMATIC
MYFORDS
What could be the cause of excessivly high idle speed between 1500 & 2000 rpm's engine is a 3.8 liter.
May 8, 2010 at 2:59 PM
  • 110,251 POSTS
A vacuum leak, throttle position sensor, idle air control valve... can cause it. Has the check engine light come on?
May 14, 2010 at 3:15 AM
