Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Thunderbird
Engine
Symptoms
Idle High
1996 Ford Thunderbird High Idle
1996 FORD THUNDERBIRD
210,000 MILES • 6 CYL • 2WD • AUTOMATIC
MYFORDS
MEMBER
1 POST
What could be the cause of excessivly high idle speed between 1500 & 2000 rpm's engine is a 3.8 liter.
May 8, 2010 at 2:59 PM
Experienced Mechanic
A vacuum leak, throttle position sensor, idle air control valve... can cause it. Has the check engine light come on?
May 14, 2010 at 3:15 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
