1996 Ford Thunderbird Exhaust
75,570 MILES • V8 • 2WD • AUTOMATIC
DELANEY259
It looks like my thunderbird had 3 catalytic converters... personally i think they are a complete waste and see no point in them. I just got a set of headers for my 4.6L and have alread done the exhaust starting after the cats... my next task is to go after the funky "Y" pipe containing the cats... i was considering only keeping one cat and replacing the other two with electric exhaust cutouts from Quick TIme Perfromance so i can run the exhaust straight from the headers in certain situations. I realized this might create a major headache with the o2 sensors... is there any way of wiring around them? taking them out of the equasion completely? reprogramming the computer? you see where im going with this? is there any way i can run a system like that which would allow me to run off of the headers with out screwing up the computer due to the o2 sensors?
[img:f22528bf11]http://www.2carpros.com/forum/automotive_pictures/181563_0517071420_1.jpg[/img:f22528bf11]
oh and im not worried about CA emmissions or smog laws because it will be an Oregon registered vehicle long before it is due for its next smog test...
Apr 21, 2008 at 7:01 PM
  • 31,937 POSTS
Hi there,
you will not be able to out smart the ECU the signal from the O2 sensors is constantly changing with will affect fuel trim and you will have all manner of problems with the ECU constantly logging a fault code, and fuel consumptions problems, (with out the O2 sensor it will go high rather than lean, they are there for a reason, mess with them at your own peril. I would recommend don't touch.
Mark (mhpautos)
Apr 21, 2008 at 9:58 PM
