1996 Ford Thunderbird Door Ajar Light
1996 FORD THUNDERBIRD
145,000 MILES • V8 • 2WD • AUTOMATIC
SINGHISEN_33
My door ajar light is on every time i have the key turned forward, but the doors are shut. Is there a sensor on the door anywhere that controls that? Do you have any ideas of what the problem might be?
Apr 26, 2010 at 8:16 AM
  • 110,244 POSTS
The light is controled by the same switch as the dome light. If it is staying on but the lights are going out, chances are there is a problem with the body control module (BCM) that is allowing power to the light.
May 14, 2010 at 3:38 AM
