Hello –
Here is the info on the compressor per your request. Sorry, the manual doesn’t have any pics.
Do you need the Accumulator-dryer or anything else for this vehicle.
COMPRESSOR
Removal & Installation
1. Disconnect negative battery cable. Discharge A/C system using approved refrigerant recovery/recycling equipment. Disconnect compressor clutch electrical connector. Remove drive belt.
2. Disconnect discharge and suction manifolds from compressor, and plug openings. Remove 4 compressor-to-mounting bracket bolts. Remove compressor from vehicle.
3. To install, reverse removal procedures and refer to the A/C COMPRESSOR REFRIGERANT OIL CHECKING article for the correct amount of oil required to maintain total system oil charge within specified limits.
Mar 4, 2009 at 9:43 AM
