1996 Ford Thunderbird
MIJLAY
  • 1996 FORD THUNDERBIRD
Noises problem
1996 Ford Thunderbird Engine Size unknown Two Wheel Drive Automatic 90,000 miles
I went to a shop to have my oil changed a few months ago and while they were doing that the mechanic told me that there is a hole in my radiator hose. I decided not to do anything about that and thought I would just do it later. I never got around to fixing it but the car still ran well so I just forgot about the problem. The other day I turned on my car and it started to make a lot of noise, especially when it shifted gears, and then it died on me. I can get it to run a little, but only if I constantly rev the engine and it will only last about 30 seconds before stalling again. I also tried driving it and I would not go any faster than 25 mph. I think the engine could be destroyed because I neglected to fix that radiator problem. Is that the problem? If so do I have to buy a new engine or is there a cheaper way to fix it?
Thursday, March 13th, 2008 AT 11:32 AM
MERLIN2021
  • 17,250 POSTS
First thing is to check the oil level and coolant level.
Then tell us what you find.
Thursday, March 13th, 2008 AT 11:54 AM
MIJLAY
Oil is fine. Coolant was empty until a few days before the problem started
Thursday, March 13th, 2008 AT 4:32 PM
MIJLAY
Also under the radiator cap there is an accumulation of some orange colored substance.
Friday, March 14th, 2008 AT 12:27 AM
MERLIN2021
  • 17,250 POSTS
OK so right now there is no coolant in it. Add some thing water, coolant, just as a test, then get a comrpession tester, remove all the plugs and test, then pressure test the cooling system. Orange coolored build up is rust.
Friday, March 14th, 2008 AT 1:22 PM
