1995 Ford Thunderbird vibration problem
GEERLINGS
Drive Train Axles Bearings problem
1995 Ford Thunderbird V8 Two Wheel Drive Automatic 100.00 miles
During driving a vibration occurs, I think in the driveline. Most of the time, but not always, it occurs around 2000RPM. It lasts for about 2-3 seconds and then it disappears. If I let go of the pedal, it disappears immidiately. In trying to solve the problem I've had the drive shaft balanced and checked the clearance. After that the problem looks less but did not disappear.
Sep 2, 2009 at 9:52 PM
RACEFAN966
  • 5,029 POSTS
Ok so have you checked the u-joints? Have you check the pinion for play? Have you checked the tires for proper balance?
Sep 3, 2009 at 3:49 AM
GEERLINGS
Yes, this has all been checked. Tires are in balance, there is no clearance (play) on the pinion and the u-joints are okay
Sep 3, 2009 at 9:31 PM
RACEFAN966
  • 5,029 POSTS
Ok have you checked the rear axle shafts and the rear hub bearings? Sense it is independent rear suspension did you check the inner axle bearings for play? How about the bushings that hold the rear diff in place? Let me know what you find.
Sep 5, 2009 at 1:44 AM
