1995 Ford Thunderbird top vents not blowing
1995 FORD THUNDERBIRD
LUKERP77040
  • 15 POSTS
Air Conditioning problem
1995 Ford Thunderbird V8 Two Wheel Drive Automatic 140k miles
My a/c was working fine and now the upper vents do not blow anymore. I've checked the fuses and are good but I do not know how to check the relays. If anyone has any info that could help it will be greatly appreciated.
Aug 27, 2010 at 9:54 AM
WRENCHTECH
  • 20,761 POSTS
Do you mean the air is coming out of the defrost vents instead of the center vents?
Aug 27, 2010 at 10:20 AM
LUKERP77040
  • 15 POSTS
[quote:fb134bd071="Wrenchtech"]Do you mean the air is coming out of the defrost vents instead of the center vents?[/quote:fb134bd071] Yes it does come out of the defrost vents.
Aug 27, 2010 at 10:31 AM
WRENCHTECH
  • 20,761 POSTS
The mode selection is done through a series of air doors that are operated by vacuum. When there is either a partial or total loss of vacuum, the system will default to either defrost or on some vehicles, heat. Acceleration can also have an effect on the doors for the same reason.
Look under the hood for a small black plastic hose coming through the firewall. Follow it to the vacuum source looking for any breaks, cracks or leaks. Also follow any other lines that branch off because they may go to a vacuum reservoir (storage tank) and a leak there will cause the same problem. Using a vacuum gauge to determine if you have full vacuum at any given point is the best way to find it. You can cut into the line anywhere and splice it back together with a piece of vacuum hose. Find the broken line, you found your problem.
Aug 27, 2010 at 10:37 AM
STEVE PERRY
i have a 1983 ford thunderbird and put in brand new blower motor ac evaperater core and heater core still no air coming out of any vents floor or defrost help me!!
Jul 12, 2016 at 12:12 PM
