1995 Ford Thunderbird ticking and less power and squeeling
127,000 MILES • V8 • 2WD • AUTOMATIC
HARLEYDIABLO12
put in a stero and later after work i drove home and one the way home my car sounded funny so i looked and the noise was comming from some where on the passenger side below the motor there is nothing loose or not hooked up so im lost can you help?
Oct 2, 2008 at 5:32 PM
RYANBLIZZ
  • 35 POSTS
I would guess that it is something to do with your A/C. I doubt it has anything to do with your radio install, it may just be a coincidence that it started at the same time.
The A/C clutch engaging and disengaging "ticks" and it would also effect your engine's power. A compressor clutch that freezes up will begin to squeal as the serpentine belt slips on it.
If it is still squealing, try turning off your A/C during the noise - if the noise stops you may need to look at getting your compressor clutch replaced.
Ryan
Oct 12, 2008 at 8:38 AM
