1995 Ford Thunderbird strut rod assembly
43,000 MILES • V8 • 2WD • AUTOMATIC
JUAN WOOD
Recently I replaced all right side front end parts on a 1995 ford thunderbird. These parts include a strut and spring assembly, a spindle assembly, upper and lower control arms, bearing assembly , tie rods inner and outer, and a strut rod. Initially the car was sent to a frame shop to correct some slight setback damage. After aligning the car today I am still hearing a poping noise when I make sharp turns and or brake suddenly. Would a loose strut rod connection cause this problem, If not what would be your assessment. Thanks this noise is driving me insane.
Feb 6, 2008 at 8:21 AM
MASTERTECHTIM
  • 4,750 POSTS
yes it would but so would a bunch of other things too. id start by making sure the strut rod bushings are installed correctly in order.
Feb 6, 2008 at 9:14 AM
