1995 Ford Thunderbird squeaking
100,000 MILES • V8 • 2WD • AUTOMATIC
DEREK808
When I'm going slow (under 25mph) I hear a slight squeaking sound when I turn the wheel slightly to the left. There's no sound on wide turns, only when the wheel turns a few inches. The noise sounds like it's coming from up by the engine or wheels. I checked the power steering and brake fluid and both are near full. What could be the cause of this?
May 21, 2010 at 1:28 PM
MANTICAMDAMAN
  • 18 POSTS
First likely cause is lower ball joints, second front wheel bearing hub, third bushings on front suspension. If the noise is a quick click or squel maybe one or two times as you turn these are likely the cause-mine did the same
May 23, 2010 at 2:56 PM
