1995 Ford Thunderbird oil pressure
DROMASTRO
  • 1995 FORD THUNDERBIRD
  • 6 CYL
  • 106,000 MILES
When ever im below 2000 rpms my oil pressure drops to nothing and the check gauge light turns on
Thursday, February 12th, 2009 AT 9:38 PM
BLUELIGHTNIN6
  • 16,542 POSTS
How long since last oil change? A plugged oil filter might drop the pressure a little. Is the engine oil full and clean? Sometimes low oil can cause a drop in pressure. Do you have the right oil in it? I've seen cars that have to have the factory recommmended weight of oil or the pressure will drop. If all is OK here I would suspect faulty oil pump.
Thanks for using 2CarPros. Com!
Friday, February 13th, 2009 AT 1:13 AM
