1995 Ford Thunderbird oil
MYSTIC
Warranty problem
1995 Ford Thunderbird V8 Automatic 143051 miles
The check engine light is on and every time I stop at a light, or stop sign the oil level light dips into the red level, and the red check guages light pops on. As soon as I release the brakes to pull off it goes back into the normal range, and the check guages light goes off as well. It also does this when I slow down to make turns. I got an oil change done on April 17th. of this year. The oil is full, and there are no leaks, as far as I can tell. what could be the cause of this? Need tune up0
Jun 19, 2010 at 7:07 PM
  • 75,988 POSTS
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on.
Jun 19, 2010 at 9:05 PM
