1995 Ford Thunderbird lights
1995 FORD THUNDERBIRD
95,000 MILES • 6 CYL • 2WD • AUTOMATIC
LUIGIJON
i lost my brake lights turn signals flashers at the same time. i bought a new multifuntion switch put it in now headlights stay on and it still did not fix the problem
Oct 8, 2009 at 7:31 PM
JDL
  • CAR REPAIR CONTRIBUTOR
  • 16,098 POSTS
Does the high-mount brakelite work? Did you check fuses? stop/hazzard fuse, turn fuse, use a testlite, check for voltage at the fuse circuits. Stop/haz fuse circuit, hot all the time, turn fuse circuit goes hot when you turn on the key. The lower stop/turn use same bulb filament, not at the same time. I'd have to check circuits to and from the multifunction switch for voltage. I can give you the wiring colors to check?
Oct 9, 2009 at 9:03 AM
LUIGIJON
well i just found out that it might be auto start aftermarket i just can't figure out where it ties into the lights
Oct 9, 2009 at 1:33 PM
