1995 Ford Thunderbird Excessive oil consumption
1995 FORD THUNDERBIRD
120,000 MILES • V8 • 2WD • AUTOMATIC
ROCKH1
4.6L
I recently purchased this car and I love it! But it is using 1qt of oil every 500 miles. I don't see any leaks, nor does it smoke on start. If I let it idle for about 15 min, it begins smoking and blows a large cloud on acceleration. After 3 or 4 accelerations, it quits blowing smoke.
I've been told that I have pull the timing chain to change valve stem seals. Is that correct? What other things might it be?
Jul 13, 2010 at 6:16 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
The smoking at initial start up is the oil leak and when this smoke happens at start up and then goes away, it is almost always a sign of worn out valve seals. If it were another seal/gasket that was leaking, the smoke would be continuous and not just at start up. If you need step by step instructions on how to replace the valve seals just let me know. You could try "engine honey" which is extremely thick lubrication that is poured into the engine oil fill opening and will help tighten up the seals. This usually doesn't help once they are already leaking though, most likely repair would be replacing the seals.
Jul 13, 2010 at 10:12 AM
ROCKH1
I don't really see the oil smoke at start up. It is only after extended idle > 15 min. Also, I don't see any smoke on acceleration whether normal or hard.
I have the procedure for replacing the valve stem seals, and I'll probably do that anyway, as Ford engines seem to need them at about 120000 miles. They're cheap. The labor isn't :-D
Jul 13, 2010 at 1:45 PM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future
Jul 22, 2010 at 6:08 AM
