engine idles fine but stumbles on acc
130,000 MILES • V8 • 2WD • AUTOMATIC
EFLANER4
Car starts fine, idles fine when accelerated under load or not under load stumbles and hesitates, eventually comes out of it and runs fine.
May 23, 2009 at 4:50 AM
More than likely this is a fuel issue but we need to run through a couple things first to prove this out or find the other possible causes.
We need to start with fuel pressure when you are trying to accelerate. Here is a guide that will help with this:
If the fuel is ok, then we need to rule out a vacuum leak, and possible air flow sensor (MAF). So here is a guide that will help with a vacuum leak:
https://youtu.be/4ktw1X4W_-k
Below you will find the info on the MAF sensor. I would suggest unplugging it and driving the vehicle. If it seems to do better then I would clean or replace it.
Here is a guide that will show how to replace it:
https://www.2carpros.com/articles/mass-air-flow-service
Let us know what you find with this and we can go from there.
Thanks
Aug 13, 2021 at 6:42 AM
