Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Thunderbird
Warning Lights
Check Engine Light
Reset
1995 Ford Thunderbird Check engine light reset
1995 FORD THUNDERBIRD
105,000 MILES • V8 • 2WD • AUTOMATIC
MANICMAN
MEMBER
1 POST
How do you reset the check engine light on a 1995 Ford Thunderbird?
Oct 13, 2009 at 2:51 AM
DOCFIXIT
Experienced Mechanic
Disconnect the negative battery cable for one to three minutes and then reconnect. the light should be out, this is an OBD1 car correct?
Oct 14, 2009 at 7:32 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
