1995 ford thunderbird
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Clarify whether the alternator was replaced and whether the warning light and gauge returned to normal. Provide any existing findings for the separate door problem.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
Discussion summary
The owner of a 1995 Ford Thunderbird reported a battery warning light and a charge gauge near the red, while the engine remained running at stops. The owner later said the problem turned out to be the alternator, then raised a separate problem with a sagging driver’s door.
Reported outcome: The owner identified the alternator but did not explicitly report a completed replacement or restored charging. The door problem remained unresolved.
No diagnostic findings or post-repair charging results were supplied. The later door complaint does not establish whether the charging problem was resolved.
