1995 ford thunderbird
JBUTLER103
i have a 1995 ford thunderbird and the battery light is on. i can sit at a stoplight and the car wont die, but the charge meter is almost in the red, can anyone tell me what is bad or going bad the battery or the alternator?
Jan 28, 2006 at 2:12 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Clarify whether the alternator was replaced and whether the warning light and gauge returned to normal. Provide any existing findings for the separate door problem.
Guidance references and applicability
Source: Original question and visible replies. Owner reports and other participants' experiences are distinguished. Next steps are editorial requests for clarification or existing diagnostic findings, not a verified repair procedure or an independently confirmed component diagnosis.
Read the replies · Discussion summary and reported outcome
LOVESCARS
  • 359 POSTS
sounds like the alternator
Jan 29, 2006 at 9:55 AM
JBUTLER103
thanks for the advice it turned out to be the alternator. My next question is my driver side door, how do i get it to close properly because it sags about an inch and i have to lift door with both hands to get it to shut
Jan 30, 2006 at 2:55 PM
Discussion summary
The owner of a 1995 Ford Thunderbird reported a battery warning light and a charge gauge near the red, while the engine remained running at stops. The owner later said the problem turned out to be the alternator, then raised a separate problem with a sagging driver’s door.
Reported outcome: The owner identified the alternator but did not explicitly report a completed replacement or restored charging. The door problem remained unresolved.
No diagnostic findings or post-repair charging results were supplied. The later door complaint does not establish whether the charging problem was resolved.
Read the original discussion
